outlander won't start in gear
Old Mar 11, 2007 | 09:40 PM
droil5's Avatar
Default outlander won't start in gear
has anyone had this problem? it will no longer turn over with brakes applied. is it a faulty brake switch somewhere.
this is a 04 outy 400 with 1500kms on it[img]i/expressions/face-icon-small-sad.gif[/img]
Old Mar 11, 2007 | 10:35 PM
randalldavis's Avatar
I had this happen on my 800 and it turned out to be a faulty pressure switch on the master cylinder.
The way I determined this was reading the news groups and simply testing to see if the brake lights worked.
When I replaced the sending unit, all worked again.
Not sure if the 400 is the same, but it may be.
Randall
Old Mar 11, 2007 | 11:20 PM
droil5's Avatar
?thanks randall i will check this.where did you find the pressure switch on your 800?
Old Mar 12, 2007 | 12:34 AM
kawiyowee's Avatar
mod, pls delete this space
Old Mar 12, 2007 | 10:27 PM
droil5's Avatar
thanks randall i checked the site you said.it turns out that it was what i thought .
the pressure switch was faulty. it is located behind the left front wheel. you can get a switch from napa
echlin # sl 134 will get one and try it $9.00 they say it is $20.00 from dealer [img]i/expressions/face-icon-small-smile.gif[/img]
Old Mar 12, 2007 | 11:38 PM
kawiyowee's Avatar
droil5, anybody, would you be kind enough to take a picture of the switch, before, after? I need it to show a guy, plus the pic would help a lot of random guys here. Thanks.
02Chevrolet
1) Engine problems..
Jun 23, 2015 12:12 AM
Dabears1983
Jun 16, 2015 12:17 PM
1000gade
May 27, 2015 12:37 PM
