400ex oil problems
Old Mar 12, 2007 | 03:06 PM
Darkkilla's Avatar
Default 400ex oil problems
my 400ex has some problems with the oil when i went riding it was running fine but then a day later i just put oil in it that day i went riding for about 20 minutes or so and then the oil is all gone and there are no leaks cause I then put some more oil let it run for about 10 minutes it was nearly gone and i saw no leaks any where. Any suggestions?
Old Mar 12, 2007 | 03:32 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Is it smoking??? You aren't burning tons of oil out the exhaust are you???? Do you end up with a bunch of oil in the airbox????
Old Mar 12, 2007 | 03:41 PM
Darkkilla's Avatar
theres not so much smoke a lil right when i get it going then it goes away in a minute and no i didnt see any build up i thought it might of been running real rich
Old Mar 12, 2007 | 10:13 PM
cluby's Avatar
Has to be going somewhere, I would take it to a good Honda dealer and request a leak down test down, anything over say 15% your motor is bad. This test will tell you where your motor is having a problem also, leaking valves, rings.
Are you using Honda oil or what kind, I've hade experince in some oil's causing oil buring and Honda won't unless your motor is worn out.
Old Mar 12, 2007 | 10:18 PM
Darkkilla's Avatar
i might try using a different oil i forgot which i was using since last time ive tested it was about 3-4 months ago.
Old Mar 13, 2007 | 11:02 AM
Red Rider
I know of several people who have experienced massive oil consumption with the 450 engine using Honda oils, and a switch to Maxima Extra cured their problem. But, the 400EX has a long history, and no such problem has come up with them.
Old Mar 13, 2007 | 04:02 PM
Darkkilla's Avatar
what exact oil i need ?
Darkkilla's Avatar
and also thanks for all the responses [img]i/expressions/face-icon-small-smile.gif[/img] thanks a lot
Old Mar 13, 2007 | 09:49 PM
cluby's Avatar
The 400ex and the 450r motor are totaly different, Honda has said themselves that the 450r motor when you run it hard WILL USE OIL.
Reactant
Mar 30, 2022 02:08 AM
ScopeZ_
Jul 28, 2015 01:44 AM
metal249
Jul 24, 2015 01:00 PM
95wolv
Jul 21, 2015 12:25 PM
yambam13
Jul 4, 2015 01:49 PM
