how do i remove the Governor(speed restrictor)?
Old Mar 12, 2007 | 08:02 PM
WoWIEE's Avatar
Default how do i remove the Governor(speed restrictor)?
Im kind of new to atvs, i mostly just know their names and just like to ride them, but ive heard about the governor or speed restrictor i heard that if you take it off it should make your atv go faster i was wondering if anybody knew were it was located and how to take it off?
Old Mar 12, 2007 | 08:16 PM
v2rider's Avatar
There is a rev limiter, that you can bypass by getting an aftermarket cdi, like a Dynatek which i have. It gives a good power boost, but not much if anything on top speed, mabey 1-3 mph.
Old Mar 12, 2007 | 08:27 PM
WoWIEE's Avatar
K thnkz but is their an easier way to remove it
Old Mar 12, 2007 | 08:29 PM
2manytoys's Avatar
Well someone might know if we knew what quad you have!
Old Mar 12, 2007 | 08:36 PM
WoWIEE's Avatar
Its on one of those kid atvs its called a 150cc hi bird Honda clone
Old Mar 12, 2007 | 09:02 PM
v2rider's Avatar
Ha!!! I guess i wouldnt know then. Good luck!
Old Mar 14, 2007 | 03:18 PM
WoWIEE's Avatar
Some1 plz help
Old Mar 14, 2007 | 11:43 PM
2manytoys's Avatar
There is no speed restrictor except for the limiter screw on the throttle. The only thing you can do for speed is change the cdi unit. I dont know anyone that has high performance cdi for the hibird atv's. The most you will get out of that 150 is about 30-35mph. You can change gear ratio to make it faster but you will lose bottom end.
Old Mar 15, 2007 | 07:37 PM
WoWIEE's Avatar
Oh ok tnkz
Old Jun 28, 2007 | 08:46 PM
yotatrailrunner's Avatar
You probably do not need to be going any faster till you learn how to spell.
