Scrambler will not shut off...
Old Mar 13, 2007 | 11:26 PM
Katy's Avatar
Default Scrambler will not shut off...
It worked fine for a while. I just finished a top end and water pump job on it. While I was at it I bought a used key switch and swapped it out. My old switch was broke with no key and I had to use a screwdriver as a key. Anyway the used one I replaced it with had all the same color wires except for one. My original had a red w/ black stripe and the new one has a red w/ a white stripe. Well, it will start fine but it will not shut off. I installed my old one thinking it would fix it but there was no change. I can turn the key off and the off/start switch on the handle bars off but the damn thing still runs. I also noticed my over heat light stays on all the time now. Anyone out there have a clue? Could it be a ground problem? How do I check them? Everything appears to be plugged in correctly. Thanks...
Next question will be how to rebuild/check the front 4X4 for problems...I pulled the allen head out of the hub and had no fluid. It looked like a seal leaked on the inside of the wheel...BOTH sides..
Whats next...
BTW 98 Scrambler 400 4X4
Thnigs done in the last two weeks.
Flywheel
Stator
CDI
Milled head 25 thou just to clean out someone elses broken piston marks
Bored cylinder
Wiesco Piston/rings
Rod bearing (upper....so far)
Water pump bearing & two seals
Gearcase oil seal
Clutch inlet ducting
Clutch outlet ducting
Fuel line
Fuel Filter
Many misc nuts/bolts/screws
Still need....
Seat, ours is not fixable
4X4 seals and whatever else I find when I pull it apart.
Chain Sprockets
Front brake diaphram
Rear brake master cylinder...
Fix the ...my engine will not shut off... problem
Old Mar 15, 2007 | 09:58 PM
Katy's Avatar
Anyone have any help why it will not shut off? I have been over the wiring diagram and they all look correct. What shuts the engine down? Grounding out the coil?
Old Mar 15, 2007 | 10:34 PM
BGRDTRUK's Avatar
Yeah if you ground the coil it kills the motor.
The switch could be wired different....look at the wire diagram for the year and model of your new switch and compare them.
Customer Service #1
May 15, 2020 08:46 AM
exmotocrosser
Sep 13, 2019 06:12 AM
mrtidy
Feb 3, 2016 05:00 PM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
