416ex
Old Dec 19, 2000 | 06:35 PM
RideRed04's Avatar
i have heard many good things about this kit. i was wondering how much people have spent on their mods, and how they turned out. if anyone has some hp numbers that would be nice. how are they compared to a 440? i would rather have a snappy quad, i dont need the speed.
Old Dec 19, 2000 | 07:12 PM
Aaron10's Avatar
This will be mods in mid Janruary
10.8:1 JE piston $100
WB Rev Limiter $100
xr400 cam $100
Lectron Carb $250
Bored to 416 $40
Port and Polish $225
3 angle valve job $50
the prices of the parts comes from one of my sponsers and he gave me 15% off of everything. So prices will run slightly higher probably.
Old Dec 19, 2000 | 07:37 PM
RideRed04's Avatar
isnt $100 kinda high for a piston? i havent looked at them, but it just seemes high. i could be way off.
Old Dec 19, 2000 | 11:26 PM
KrazyNeighbor's Avatar
i took the cheapest way, and stillg ot some noticable power
piston 10:8:1 JE - 130
gaskets - 30
bore job - somewhere areound 50 or 60, i forget
as soon as i put a cam in this bitsh, it's gonna move. It moves in the mid range now, but probably only gave me like 4 mph on the top end
Old Dec 20, 2000 | 01:49 AM
hakmazter's Avatar
love mine. piston is 130, gaskets are 30, and the xr400 cam from servicehonda is 110. made a big difference.
Old Dec 20, 2000 | 12:17 PM
Steven's Avatar
I ordered all the parts for a 416. I got an JE piston 2mm over, 11:1 compression, and a cam from TC racing, and gaskets. I put it all together today, but it won't start up. It is in a cold garage, so I'm wondering if I should warm it up in a warm one. Then I thought I might have the timing of 180 degrees, but it still won't start. I don't know what to do next. I think I put everything together right. Did anyone else have this problem. Maybe I'm not trying to start it enough. It should start up fairly quickly though. I don't see what would make it start so hard. Any help would be appreciated. I have rebuilt one before, so this isn't my first. Please help.
Old Dec 20, 2000 | 12:37 PM
Aaron10's Avatar
Got fuel right? Turn you fuel switch to Reserve the gas pulls harder. See if anything happens then. Also use your choke of coarse.
Old Dec 20, 2000 | 01:06 PM
ddog400ex's Avatar
If you replaced the rev limiter with a white bros. Install your stock one and try to start it.
I had to send mine back three times before I got one that would start my quad.
Good Luck !
DDOG
Old Dec 20, 2000 | 01:36 PM
GrimReaper's Avatar
I had the same problem with my White Bros. cdi. Big piece of crap in my opinion. i'm gonna get a Sparks or TC Racing cdi box.
Old Dec 20, 2000 | 05:32 PM
RideRed04's Avatar
how does just a high compression piston and a cam work (stock size)? i'm glad i heard that white brothers cid's are crap because i was considering one. how do the xr250 ones work?
richard212
Jun 19, 2008 10:21 AM
Ish416
Jun 3, 2005 10:10 PM
ineedatrailbike4me
Sep 14, 2004 12:37 AM
sn0wrider
Feb 12, 2004 09:37 PM
