old gas
Old Mar 14, 2007 | 04:36 AM
kongmen's Avatar
Default old gas
I just took my 04 v out from storage after about a year and change and it won't run without using the choke. I put stabill in it when I stored it but maybe it's been to long. Can someone tell me where to start on getting it running right? Thanks.
Old Mar 14, 2007 | 10:23 AM
frotrk's Avatar
Default old gas
did you run the stalbil fuel thru the engine after you put it in the tank. if not the carbs may be gummed up. put in a little freash gas with some carb cleaner in it and run it on choke a little while and it may may clean out the system. then change the oil and filter.
Clark
Old Mar 15, 2007 | 01:05 AM
kongmen's Avatar
Default old gas
I'll give it a try.
Old Mar 17, 2007 | 10:13 AM
kongmen's Avatar
Default old gas
I have not had a chance to look at the v yet but I've been reading the forums concerning my situation and it looks like I might need to clean the pilot jet. Does anyone have some pics they could put up that shows how to get to the pilot jet?
Old Mar 17, 2007 | 04:44 PM
QWODER's Avatar
Default old gas
It does sound like the pilot jet.I havent had the V carb apart but on most carbs you turn the carb upside down and take the bowl off the bottom of the carb usually 4 screws hold it on.after you take the bowl off you should see 2 jets that you can screw out ,the smaller jet is what your looking for.The hole is usually so small you can barely see through it.Well good luck and I hope the V carb is like most carbs ,if not then forget everything I told you.
