2002 trx250es spark plug firing problem
Old Mar 14, 2007 | 04:24 PM
kggracer's Avatar
Default 2002 trx250es spark plug firing problem
Having problems with spark plug not firing. Have replaced it. No change. Can ayone tell me where to start troublshooting? I know its going to be a pain to find. I have a test light. The wires going to coil does not show fire to them. Also, the wires coming out of CDI does show fire to them. I need help before I put to much money into non refundable electrical parts.
Thanks
Old Mar 14, 2007 | 08:14 PM
bombrider04's Avatar
Well if you said if you replaced the plug thats where I would have started also and if the coil isn't getting spark and the cdi is getting power and giving an output then you coil is bad and you will need a new one or you have a ground problem or you connection is dirty from the coil to the cdi, so chekc the connections first and I would try and get either a used or a new coil and you should be good to go if it is getting power how you tested...Welcome to the forums.
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
njrider64
Jul 4, 2017 01:40 AM
WilliamBos
Sep 30, 2015 08:08 AM
02Chevrolet
Jun 23, 2015 12:12 AM
Ask the Editor
Jun 3, 2015 04:16 PM
