600 SPORTSMAN RUNNING BAD
Old Mar 18, 2007 | 12:20 PM
onesavage's Avatar
Default 600 SPORTSMAN RUNNING BAD
hey guys i have a question for ya.. my neighbor has a 04.5 600, and at about 4300rpms the thing starts to pop and back fire, it also idles realy ruff and is VERY cxold blooded..i have replaced the plugs they were a month old and fouled i have replaced the fuel filter and cleaned the pcv systemstill no change , i have not had ANY running problems w/ my lil 400.. can you gust help us out it is de-thawing up here in michigan and time to ride...........thanks ahead of time
savage
oh ya, the intake boot is ok -- checked for air leaks
Old Mar 18, 2007 | 12:30 PM
ncriderforks's Avatar
So it runs good and smooth up to that point? Plug wires ok and in good contact? Check and make sure the air filter is installed correct. Make sure the gray foam that fits around the snorkal is not getting sucked in to it and causing it to have an air resrtiction. Make sure the airbox lid is on correct, the drain plug for it is in place and the air box is connected to the carb ok and the carb to the intake ok. You said you replaced the plugs. Were they white or black? It sounds like it could be an air box restriction based on the rpms you described. They are bad for getting that foam that is around the snorkal or the foam that some have up around the gastank where the snorkal goes up under the plastic getting sucked into the snorkal tube. If this is the case, the plugs would havve been black. No, it will not run correct withe airbox lid off so you can't remove it and try it. Check this first and give us a reponse.
Old Mar 18, 2007 | 12:44 PM
onesavage's Avatar
yep plugs are black... no restrictions that i can find...
Old Mar 18, 2007 | 01:00 PM
onesavage's Avatar
sendori , can ya help us out!!!!!PLEASE!!!!!!!!!!!!!!!!!!
Old Mar 18, 2007 | 03:07 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
well its getting too much gas for sure. did you pull the carb off to make sure things were all set and the float level and needle and seat were all good. another thing is the valves adjusted right, cam not worn out. this causes backfiring sometimes when lobs get worn off. like was mentiioned make sure theres no restrictions and vent tubes arent blocked or crimped. best i can thing of right now.
Old Mar 18, 2007 | 03:59 PM
onesavage's Avatar
yea i am going to pull the carb and go through it and do a good cleaning and adjusteing ,, not till next weekend though....as always thanks stendori
skittero
35
Mar 1, 2019 12:39 AM
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
gfl0224
Jun 27, 2015 06:52 PM
Raccar1
Jun 18, 2015 02:17 AM
jrooker6
Jun 17, 2015 12:28 PM
