revving really high 200s
Old Mar 18, 2007 | 01:44 PM
loadder's Avatar
Default revving really high 200s
i just got an 83 honda 200s and upon starting it rev's really high, i switched carbs with an 84 200s and same thing, so my question is, what can cause or is causing my 200 to do this, the cable is new and is not in a bid, mabey too much slack, but i cant get any more adjusment out of her, is there a timing issue i can look into ?? any help will be appreciated, thanks
Old Mar 22, 2007 | 07:14 PM
PlatinumDogg's Avatar
Check for air leaks around the carb.
Old Mar 29, 2007 | 10:53 AM
liquiddarkness's Avatar
Maybe replacing the intake boot+rubber oring might help. Along with adjusting the valves and re-setting the cam chain.
Old Apr 3, 2007 | 04:14 PM
loadder's Avatar
got this problem fixed thanks guys, lots of help as to where to attack, it wound up being the throttle cable in a bind by being wraped around the frame under the tank, once unwound, it free'd it up to let then spring actually pull it closed and that did the trick, now i have problems with my 84 200s and have posted a question about the magneto and coil, it all the sudden wont start ,
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
dannytas
Sep 26, 2017 06:31 PM
r1pilot83
Sep 27, 2015 07:38 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
