95 sportsman 400 question
Old Mar 18, 2007 | 08:08 PM
hoytultratec's Avatar
Default 95 sportsman 400 question
when it gets warmed up after driving it awhile its hard to start, it starts back up when it cool down fine... where should my buddy start ? it is a 2 stroke.
dirty carb or possible rebuild???
hoyt
Old Mar 18, 2007 | 08:18 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
just a guess, but see if theres any pressure in the gas tank by releasing the gas cap. if there is maybe the vent lines are plugged or crimped and it starts to vabor lock kinda. if the carb was dirty it would start hard all the time.
Old Mar 18, 2007 | 08:24 PM
thanks was kinda thinking that but thought i would ask because im sure this has happened to somebody else on here..we will check for that when my buddy gets it.
thanks hoyt
Old Mar 18, 2007 | 09:24 PM
ncriderforks's Avatar
I would start with a compression test. They get hard to start when you get down below 90 psi. Also, does it run fine after it starts? Does it run fine the whole time until you shut it down? If it starts boggin some or starving for fuel while running then it is possible that crank seals are bad. It could be sucking air through the seals or an intake leak. But in most cases it would run bad all the time if that were the case but the compression would still be good.
Cole Hadden
Jun 15, 2025 09:05 AM
1966F100
Jul 12, 2015 03:08 AM
tporath
Jul 11, 2015 12:31 PM
toonces
Jul 11, 2015 12:01 PM
200es
Jul 10, 2015 09:09 AM
