Front Brakes
Old Mar 20, 2007 | 01:29 AM
Mudmen's Avatar
Default Front Brakes
I took my 650 out last weekend for some fun in the sun and noticed that my front right brake wasnt working. The brake handle was not as firm as I remember, it seems to be easier to squeeze.
Could it be the master cylinder, piston in the caliper, bad fluid, air in the fluid or a combination of any or all? I see no leaks anywhere even when squeezing the brake.
Thanks!
Old Mar 20, 2007 | 11:31 AM
bombrider04's Avatar
I would say first check to see if you have air in the lines or are low on fluid...If you aren't how are your pads and I would say if all of this is fine and your brake lines are sealed and have no leaks or anything I would say either the plunger went bad in the master cylinder or you need a new caliper or both calipers.
Old Mar 20, 2007 | 01:01 PM
Mudmen's Avatar
Thanks for the reply, I will look into your suggestions. I havent looked yet into the calipers yet, but can you replace the pistons in them like you can in cars or do you have to buy a whole new caliper?
Scott
Old Mar 20, 2007 | 03:40 PM
Good ? um you may be able to, but would prob be better off just buying a new one or used one from ebay.
Reactant
Mar 30, 2022 02:08 AM
greg74
Sep 10, 2019 03:03 PM
carolinabomb
Jul 26, 2015 08:40 AM
timster911
Jul 13, 2015 01:57 PM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
