DS650 PROB
Old Mar 20, 2007 | 06:35 PM
YamahaEater's Avatar
Default DS650 PROB
havin a prob wit my 2000 ds650 i just got it out of the shop about a month ago and they cleaned the card and adjusted the valves it was runnin fine but then it started sputtering and not being responsive so i cleaned the card again and put new spark plugs in her and she ran like a champ 4 about 15 min then it started doing it again so if anyone can help it would be sweet thanks
daniel
Old Mar 20, 2007 | 06:38 PM
Tpsycho's Avatar
My Bomb Busa is done now and WOW what a rush this thing is scary fast. I love it
Default DS650 PROB
I would make sure that your fuel tank vent hose is not plugged. Try taking off the cap and see if this cures your problem. If not make sure your carb is getting enough fuel take your line off and open your pitcock valve and make sure it flows freely.
Old Mar 20, 2007 | 07:02 PM
MrMeaner's Avatar
Default DS650 PROB
Also you might check the fuel line. I had one that was breaking on the inside and getting pieces in the carb. Do you find anything in the carb when you clean it?
Old Mar 20, 2007 | 07:17 PM
Default DS650 PROB
no it looks clean 2me but it runs fine then it gets in its moods back and forth back and forth i disconnected the air box and played with it then it ran fine for like 1 min started doing it again.But when i got it back from the shop it would only run good on the reserve and i would put it on ON and it would run funny so i just left it on reserve and it ran fine 4 a month until now.
Old Mar 20, 2007 | 07:46 PM
Tpsycho's Avatar
Default DS650 PROB
Sounds like your pitcock valve is plugging up or your strainer screen is plugged. check the flow on your fuel line and see if your getting a good flow. Might be a stretch but check your diaphrame and make sure that you don't have any tears in it and the vent line off of your diaphrame is not plugged. sounds like a fuel flow problem. also check your plug and see if it is running lean or rich your problem could be you are getting to much fuel rather than not enough if this is the case go into the needle and seats of your carb and also check your float level.
Check those things and see if anything helps keep us posted. Good Luck
Old Mar 21, 2007 | 02:25 PM
Default DS650 PROB
ok i checked the flow of gas flows good so after that i tried taking it out again ran fine for 5 min then it started doing it again bogging down it wont rev high and the exhaust makes a putter sound like its clogged or sumthing but it dosnt stall out and it idles fine so after a few min of putting around cuz thats all i could do i hit the gas a couple of times and and it ran good again i was also wondering if it could be the denso rev box just askin i dont know what the prob is so if anyone has any more ideas it would be helpful thanks.
Old Mar 21, 2007 | 06:44 PM
MrMeaner's Avatar
Default DS650 PROB
I had a simular problem once. Mine would bog every once in a while and I finally found it. I had bought an after market gas cap. There was some caulk or sealent in it to hold the rubber ring in it. A piece of it had fallen into the tank and every once in a while it would block the flow of gas. You might take the tank off and drain it and take the pitcock off also. Still sounds like a gas flow problem
Old Mar 21, 2007 | 08:25 PM
KIWI2's Avatar
Default DS650 PROB
You say it ran good on reserve for a while. Well the DS tank has a large reserve, so it feels like your out of gas. Look inside the tank and look at size pickups and makesure the fuel level is above, and if you can see the screens on the pitcock are clean. Does it run good with a full tank? Also like someone mentioned check your fuel cap, they plug real easy. Also the mile of vent hose under the tank pinches easy too. I know its frustrating[img]i/expressions/face-icon-small-mad.gif[/img]Good luck.
Old Mar 21, 2007 | 11:35 PM
MrMeaner's Avatar
Default DS650 PROB
Thats good advise. I ran mine out of gas and could still see gas in the tank. Put it on reserve and she ran again
Old Mar 25, 2007 | 03:29 AM
TMay4's Avatar
Default DS650 PROB
i had the same prob with my 2001 ds650 all i had to do was add oil from what they told me when i asked a mechanic about it that the rotax engine oil dosent have to be changed as much as a regular engine but it usues oil so u r supposed to add sum back every couple weeks no more than 1/4th of a courth in about a months time should need to be added though but after i did that myne ran great untill i bent the ti rods into U's jumpin a table top
MRDS650
Feb 22, 2026 11:26 AM
BigCam
Sep 16, 2015 01:53 AM
toonces
Aug 5, 2015 05:55 PM
southbayman
Jul 24, 2015 09:30 AM
Fijit
Where to Ride
Feb 6, 2000 01:01 PM
