No spark - have tried a bunch of stuff. Help!!!
Old Mar 22, 2007 | 01:14 AM
azkickn40's Avatar
Default No spark - have tried a bunch of stuff. Help!!!
We have 2 70cc Hensims that I'll call QuadA (one with problem) and QuadB (one that is running now). QuadA has about 12-15 hours on it. I have changed the oil at about 7 hours (2 rides ago) and put in 1/2 quart of 10W-30 and have changed the spark plug to an NGK CR7HSA (prior to our most recent ride).
Took it out the other day for my 6 year old to ride and it ran great as it always has, so far... He wrapped it up for the day and turned it off. I went to shuttle it back to my truck and it started for a few seconds and then died. Started it again and it died yet again. It hasn't started since then.
I checked for spark and don't have any both with new plug and old plug.
Here is what I have checked:
- Good fuel flow (not that it matters w/ no spark)
- Safety wrist thing and leash ? both have correct continuity
- Fuse - OK
- Battery - OK
- Air filter - it was dirty (since cleaned), but still no spark w/o air filter on there.
- No visible damage to wires
- looks like everything is hooked up
- Took from QuadA and put on QuadB the old spark plug and got spark, coil and spark plug wire, voltage regulator, and 2 "black boxes" that are close to the coil (I'd assume one is the remote kill because looks like antennae coming out of it) and ALL WORKED on QuadB.
I am at a loss - can you help me out on some things to check to get this running again?
Thanks,
Brian
Old Mar 22, 2007 | 01:37 AM
Medic73's Avatar
When you put the quad A spark plug on Quad B did it start or didn't it. Not really sure what is going on maybe you might have a bad plug even the new brand tend to have a bad one every now and again. In all honesty if quad A's spark plug got you spark with quad B it seems like a plug problem. let me know how everything turns out. Im not sure how the chinese quads work but have worked on my share of small engines
later
Brett
Old Mar 22, 2007 | 11:15 AM
azkickn40's Avatar
later
Brett
Brett,
I didn't take the plug out of either machine, but took the OEM (Chinese) one and put in the spark plug on both machines and got a nice blue spark from QuadB and nothing from QuadA. He ran QuadA w/ the New spark plug for well over an hour straight with no problems before this happened.
I can try swapping the spark plugs if you think it may help.
Thanks!
Brian
hueby
1) Engine problems..
Aug 29, 2015 08:34 AM
hueby
Aug 28, 2015 07:26 PM
vinrum
11
Aug 26, 2015 06:44 AM
TheHood
Aug 8, 2015 05:49 PM
ScopeZ_
Jul 28, 2015 01:44 AM
