2006 honda rancher shifter
Old Mar 24, 2007 | 07:16 PM
Littlebull75's Avatar
Default 2006 honda rancher shifter
I recently purchased a 2006 Honda Rancher es and wanted to know if it is at all possible to change to a manually shift (foot lever) and if possible what do I need to do to change it
Thanks for your help
Old Mar 24, 2007 | 07:34 PM
gary56's Avatar
I don't know how to change, but are you having problems with your electric shift?
Old Mar 24, 2007 | 08:04 PM
I have noticed that sometimes around the pasture that I have to push the up/down button a couple of times before it will shift, it may be that I need to push harder on the button, I don't know
Old Mar 24, 2007 | 08:19 PM
ForemanDan's Avatar
I think there is some kind of rev limit for some of the shifting. Not sure if thats true.
Old Mar 24, 2007 | 09:52 PM
RedneckRandy's Avatar
My 2006 Rancher ES will shift at WOT.
Littlebull75,
Mine has a light touch to make it shift with the buttons.
Randy
Old Mar 25, 2007 | 08:18 AM
HondaMechanic's Avatar
none
Old Mar 25, 2007 | 08:26 AM
gary56's Avatar
my electric shift stopped working, and now I can't put into gear manually, does any one have an idea what is happening trx350 honda only 7 months old
Old Mar 25, 2007 | 09:06 AM
Scannerboy1968's Avatar
Gary 56,
Mine did the same thing but I was way way out on a mountain trail in WV. Luckily I figured out what it was on the spot. We had been going through some extremely rough terrain and something knocked the wire off underneath on the shift solenoid. It was an easy fix. Hope you figure it out.
Later, Andy
Old Mar 25, 2007 | 09:23 AM
gary56's Avatar
Thanks Andy, I am going out and look at that right now, see if that can be the problem. Gary 56
Old Mar 25, 2007 | 10:38 AM
ForemanDan's Avatar
Littlebull75,
Randy
When downshifting to first?
