Just got Honda 185 ATC need help please? :-)
Old Mar 24, 2007 | 07:18 PM
oscarmayer's Avatar
Default Just got Honda 185 ATC need help please? :-)
I have a few questions if someone coudl be gracious to help I'd be very appreciative.
The pull starter assembly is completely missing. I am geting the entire essembly but it's a 3bolt pattern. The crank case has 4 bolt pattern. Is one of the bolt holes not used? is there another piece ?i will need?
starter area
there is a cable missing that goes to the decompression linkage. Where would it connect form there?
decompression
This is the ignition section. i don't have the cover yet, but the bolt is loose. is there something that is missing from this area?
ingition area
I'm missing the rear brake lever that the cable goes too. any clue where to get one? the photo shoes the entire rear section.
rear area
Here are 2 other general pics.
side area
side area far away
I am also needing to knwo what year/model wheels will fit on this trike? The one you see in the pic is not going to work, it's too big and they jsut stuck it on there to mover the trike around. So i'll ned a new wheel and 3 new tires.
the motor is in good shape i can feel plent of compression and turns just fine.
Thanks again for any help someoen can provide.
Mike
oscar@mayer.net
Old Mar 27, 2007 | 11:09 PM
oscarmayer's Avatar
wow 1 week and no help
Old Mar 29, 2007 | 08:37 PM
liquiddarkness's Avatar
I would try to find a manual.
Old Mar 30, 2007 | 08:39 PM
SMFREY's Avatar
A manual on this bike is worth it's weight in gold
They are kind of different and I found this out
I found 2 of these at a yard sale about a year ago
Both 82 185s
Making one run it hauls
Other is parts
On the pull start there are only 3 bolts used
There is a decompression cable going from the pull start to the cyl head
In looking at photos I see your spark plug wire is missing
I see allot is missing
But it looks repariable
I can see some work will be needed to get running as it has been out in weather
Wheels are same as 110,185s,200 series
They are not hard to come by can still get in aluminum
I am sure RM in colorado you can order with tires cheep
good luck
Ray
Went to Glamis last weekend
Had Blast
took the 3 wheelers out Sat afternoon
2- 110 and 1-185s
SLOOOOW up hill ReaLLLLLY fast down hill
wendal
May 9, 2024 09:29 PM
wendal
Oct 31, 2017 03:31 AM
rgjackson
Sep 17, 2015 11:21 AM
wendal
Sep 15, 2015 01:50 PM
Jason Campbell
Sep 7, 2015 02:25 PM
