Twisted off Oil bolt
Old Mar 27, 2007 | 05:31 PM
kyledc18's Avatar
Default Twisted off Oil bolt
I just twisted the oil check bolt on the tranny side of my 450r and i had the torque wrench set to 9ft pounds (witch i believe is right) any ideas wy it snapped? If i have to loosen and retighten this bolt every day i dont want to snap it again.
Old Mar 28, 2007 | 06:49 AM
cajunkid's Avatar
Yes! find a easy out smaller than that size hole drill the center of the plug put easy out in and try to unscrew the plug. If that does not work. Get a drill and redrill the size it calls for then get that size tap, and retap the hole put new plug. Once all that is done you will have to flush your motor out a few times to get shavings out. About the only thing you can do. (GOOD LUCK)
Old Mar 28, 2007 | 08:11 AM
kyledc18's Avatar
I got the bolt out, but does everybody check this plug before riding? cause i was wondering why it would snap if a had the right torque,mabe i just wont put it as tight anymore
Old Mar 28, 2007 | 08:29 AM
cajunkid's Avatar
The torque should not be more than 5 to 8 pounds on a drain plug. I set mine at about 7 pounds never had any trouble or plug backing out.
Old Mar 28, 2007 | 09:14 PM
bombrider04's Avatar
I did that to mine also, but it came out luckily and I had mine set at 9nm not ft pds...I figured out that my torque wrench needed to be recalibrated and that is why it happened...So I went to the local auto store and got 10mm bolts which is what it calls for and used them and they were the exact same size and everything...I just tighten it up by hand now and it does the trick...What I found out to make it easier for you is when you check the hole some oil keeps coming out so put the bolt back in just a little and jack up the side of the quad so you wont have anymore oil flowing out...take the bolt back out and clean the bolt and around the hole, put the bolt back in and tighten her down and you are set.
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
firsttimerider
Sep 20, 2015 09:07 PM
89Lt250r
Sep 7, 2015 07:53 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
