engine problems 500
Old Mar 30, 2007 | 09:30 PM
furnaceman's Avatar
Default engine problems 500
Just looking for some advice on maybe where to start with this thing. I have a 96 sportsman 500 that has developed a problem with starting. I tried to start it with the choke as I usually do when it's below 60 degrees out. but it won't start. I have to take the choke off and feather the gas. Once it starts up it runs great and restarts fine when warm with one hit of the starter. when it's warmed up and she fires right up. I'm thinking the choke is out of adjustment. I also threw the choke on when it did fire up and it died. I still have to go through and do my checks but was wondering if anyone else has had this problem?
Bill
Old Mar 30, 2007 | 10:37 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
it might be putting too much gas in by the sounds of it. im surprised you need to choke it @ 60 degrees.
Old Mar 30, 2007 | 11:26 PM
furnaceman's Avatar
well I probably don't need the choke at 60 but It needed it today and it was 49 degrees. I'm going to check the carb settings tomorrow.
Bill
Old Apr 2, 2007 | 06:44 PM
Russ136's Avatar
Check your valve clearance. Valves actually tighten up to the point that they don't close tight causing low compression, hard starting when cold.
Old Apr 2, 2007 | 08:13 PM
furnaceman's Avatar
thanks! I'll check the valves. they were checked about a month and a half ago could they loosen up that quick?
Bill
Old Apr 2, 2007 | 08:22 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
they shouldnt be loose if they were done a month ago.
joshuafromny
Jun 22, 2015 05:30 PM
scaldwellk
Jun 19, 2015 05:08 PM
generalpops
Jun 5, 2015 08:23 PM
generalpops
Jun 3, 2015 08:25 PM
kevbowe
Jun 1, 2015 01:17 AM
