416ex?
Old Apr 1, 2007 | 11:42 PM
7wrobben's Avatar
Default 416ex?
ok im thinking about going to a 416 for me 400ex, could someone tell me what all needs to be done for that, i dont really understand the boring, is it the sleeve that gets bored out or what, and do u need heavy duty studs installed with that kit or does it really matter, any help would be greatly appreciated, thanks in advance.
Old Apr 1, 2007 | 11:58 PM
Martianman's Avatar
Default 416ex?
Its an .080 over bore,I have the 12.5:1 JE piston with web track cam,1mm bigger intake valves,port work,Curtis Sparks exhaust and it runs very well with torque everywhere.Later
Old Apr 2, 2007 | 01:11 PM
7wrobben's Avatar
Default 416ex?
the way im taking it is u do not have to do any machining at all to the cylinder or sleeve for the .080mm piston, just a hone for the rings to seat good is this correct?
And do u have to put in a heavy duty timing chain and head is a good thing to do or is it really not the much of a major thing u need to have done?
Old Apr 24, 2007 | 09:25 PM
carte's Avatar
Default 416ex?
ahh dude, if your only going with a 416 kit then you will need to have you cylinder jug bored. fortunatley you still get to use the stock sleeve. then as far as the stronger studs...i dont think its necessary. i have the work on my and run it hard with no probs .
richard212
Jun 19, 2008 10:21 AM
Ish416
Jun 3, 2005 10:10 PM
ineedatrailbike4me
Sep 14, 2004 12:37 AM
sn0wrider
Feb 12, 2004 09:37 PM
