Trailblazer front cover on scrambler
Old Apr 3, 2007 | 06:46 PM
sic500's Avatar
Default Trailblazer front cover on scrambler
Hey Guys has anyone put a trailblazer front cover on a scrambler?I just installed the new front cover and i think it looks great with all 3 lights but i need to know if i should splice the wires from the new light to one of the wires from the two that already exist..any thoughts??
Old Apr 3, 2007 | 11:41 PM
sic500's Avatar
anyone electricly inclined??
Old Apr 3, 2007 | 11:49 PM
SCRAMMYTODD's Avatar
Does it have a high and low beam built in? My old Scrambler (03 500) had wires under the hood to tie into for high, low, and reverse as well as keyed power I think. I would use them if your bike is the same. Just use a test light, they are harnesses that just end. I think they were green, yellow and purple??? Have a look and see what you find.
Old Apr 4, 2007 | 12:04 AM
sic500's Avatar
I just checked the polaris site and it doesn't say anything about hi/low beams so i am guessing that it does not.. That is what i was worried about.If i spliced the wires into the existing headlight wires and ran it on low beam it should be o.k. but than if i switched to hi will it BLOW or just short out or even ruin all of the other electrical systems???
Old Apr 4, 2007 | 12:08 AM
How many wires on the light??
Old Apr 4, 2007 | 12:15 AM
sic500's Avatar
i believe there are only two. The scram is at a friends house right now so i can't even check...but if i had to guess i would be confident in 2.
Old Apr 4, 2007 | 12:28 AM
Well check under the hood for the colored pigtails. If they are there use a test light to find either the high or low beam, whatever you prefer, and then ground it to the frame. It doesn't matter what way current flows thru the bulb. And make sure you leave enough wire to pull the hood off when needed
Old Apr 4, 2007 | 12:33 AM
sic500's Avatar
Thanx for the advise i definately have to make the wires longer...don't even think they are 6 inches long..Again Thanx i will let you know the outcome and hopefully soon i will get some pix on my profile.
Old Apr 4, 2007 | 12:39 AM
What year is your bike?? And is it a 400 or 500??
Old Apr 4, 2007 | 12:47 PM
sic500's Avatar
2004 500 h.o.
