sand blasting, bead blasting
Old Dec 21, 2000 | 09:30 PM
Luckyhands's Avatar
Hey whats up?
Does anyone here know about bead blasting. I know how to sand blast. What abrasives is the best for bringing out the shine on the cases of a motor?
And where can I buy this abrasives? Thanx
Old Dec 21, 2000 | 09:47 PM
CaptNemo's Avatar
Bead blasting is about the same as sand blasting, but it doesn't rough up the surface as badly. It will remove any polishing that you may have done.
Check the yellow pages under "Sandblasting Equipment and Supplies". 3M makes a Scotchbrite wheel for a bench grinder or buffer. They're great for removing paint and light corrosion prior to buffing out the parts, as they don't leave deep scratches.
Old Dec 22, 2000 | 10:51 AM
hiofcer's Avatar
If you have a blasting case, I would highly suggest walnut shells. They produce a lot of dust and you won't want to breathe it. They do a wonderful job and won't warp the metal like sand.
This will strip any paint or powder coating you may have. But, it leaves an excellent surface prior to polishing.
Eastwood company has an excellent selection.
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 20, 2015 10:21 PM
rawbdiggity
Sep 7, 2015 12:05 PM
Sep 2, 2015 11:15 PM
