v2 650 Blet slipping under load
Old Apr 8, 2007 | 04:53 PM
brpbear's Avatar
Default v2 650 Blet slipping under load
A freind has a v2 650 that has been slipping the belt after he put on 26" Big Horns.I would like to know what clutch kits are avlable and how well they work and v2 I will be nice.
Old Apr 8, 2007 | 04:59 PM
brpbear's Avatar
The belt slips in wet deep snow
Old Apr 8, 2007 | 05:40 PM
v2rider's Avatar
For some reason, his belt may be getting wet. I for one have no problems in water or mud. But if its a early year V2, it may be leaking somewhere. Highlifter has some good clutch kits. Otherwise, have him take the belt cover off, check the deflection and wear on the belt, and put a new gasket seal around the belt cover. He can also tighten all of his hose clamps coming off the front airbox and main airbox to get a good seal
Old Apr 8, 2007 | 07:11 PM
brpbear's Avatar
I have seen snow dust cause the belt to slip but this more like the belt needs to be griped better. Will these kits help.
Old Apr 8, 2007 | 07:27 PM
v2rider's Avatar
Yes
Old Apr 8, 2007 | 08:47 PM
buckaroo50's Avatar
If the belt is slipping then obviously there is a problem with the belt, putting in a clutch kit is not going to cure the problem until you address the real issue.
Old Apr 8, 2007 | 09:43 PM
Chumley's Avatar
Normally I would agree but we're talking about the infamous V2 clutch here, notoriously crappy. I would recommend a clutch kit for ANY and EVERY V2 owner.
Old Apr 8, 2007 | 10:43 PM
buckaroo50's Avatar
Was not aware that the v2's had a history behind the clutches... I think I would still start with the simple and least expensive, checking, measuring, cleaning etc...
Old Apr 8, 2007 | 11:48 PM
MUDSPY's Avatar
dalton clutch kit new dayco belt and presto no belt slip exspecally with stock tires there should not be a problem also a lot better performance
Old Apr 8, 2007 | 11:52 PM
Chumley's Avatar
New primary and secondary springs, along with a night tight belt will cure it. Pretty good chance a new belt won't be needed, nor will a full clutch kit.
