2001 bayou 220
Old Apr 9, 2007 | 12:17 AM
dorrt's Avatar
Default 2001 bayou 220
Ok I need help. I just bought a 2001 bayou with what i was told a slight oil leak. well i bought it and brought it home without even starting it. well now that its in my garage it wont go into any gears..it feels like there is tension on the shifter but after what would be shifting it the atv still rolls like its in neutral.all ive done is the replaced the starter moter and relay assembly with ones off my 89 because they were missing on the 01..any ideas??? your help is needed because al im hearing is complaining from the wife..
Old Apr 9, 2007 | 01:45 AM
bmj67's Avatar
have you checked the clutch adjustment. also it could be that the shoes on the primary clutch bell on the crank are shot or stuck maybe.
Old Apr 9, 2007 | 01:56 AM
dorrt's Avatar
ok im lost how do i do that?
Old Apr 10, 2007 | 12:37 AM
bmj67's Avatar
on the right side of the atv as you are sitting on it normally there is a little black cover with 2 screws. remove the screws then loosen the 12mm lock nut under the cap. turn the flathead screw clockwise until resistance is felt then trun the screw counterclockwise until resistance is felt. hold the screw from moving and tighten the locknut.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
35dodge
Sep 29, 2015 09:40 AM
jsmit116
Sep 18, 2015 10:34 PM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
rcappie4
Sep 9, 2015 07:04 PM
