400ex: disconnecting wires to headlights
Old Dec 22, 2000 | 03:55 PM
tenney's Avatar
Ok this may be a dumb question, I don't know what I am doing wrong. I am taking the front plastic off my 400ex and can not get the wires to the headlights to disconnect. It looks quite simple but it will not disconnect. If anyone has any tips that would be great! Thanks!!
Old Dec 22, 2000 | 06:43 PM
weedman's Avatar
pull, pull hard
Old Dec 22, 2000 | 06:52 PM
njg86's Avatar
wire clippers = disconnected headlight wires
Old Dec 22, 2000 | 07:36 PM
Hyper440EX's Avatar
It happen to me the first time, I spend almost 40 minutes to do it, but is the easy think in this world, just use a pen a push the small pin, and pull at the same time the connector, it will release very easy without pull hard and destroy the connector.
Old Dec 22, 2000 | 09:21 PM
wallsenterprises's Avatar
So, did you get the wires disconnected O.K.? I had the same issue. Those two connectors, one for lights and one to the ignition switch look like they have a latch on each side (4) that you need some wonder-tool to press all 4 at the same time you pull, or two buddies with screwdrivers in hand to help.....
Lemme know....Thanks!!!!
Old Dec 22, 2000 | 10:43 PM
tenney's Avatar
Yea thats exactly what I was thinking. Maybe there is some tool to unhook these. I didn't want to break them. It is too cold atm so I might not get to it until it at least gets above zero.
Old Dec 23, 2000 | 12:25 AM
FAST453EX's Avatar
THESE ARE NASTY, I fought with them for so long! There is three tabs which all have to be pushed in u gotta pull hard. It should be eliminated soon on mine, I want to put easier plugs on it, maybe these are better waterproofed though.
Old Dec 26, 2000 | 06:28 PM
Hyper440EX's Avatar
I'm late to answer you, sorry about it but I was on a trip.
Is very easy to do it, find the pin on the connector, push it and pull the connector, no need a special tool or a gorilla to do it.
After find the way you would be amazed in how easy it is.
Old Dec 27, 2000 | 04:59 PM
Wicked400EX's Avatar
That is very simple. you're trying too hard! Once you do it right you will say to yourself damn that was easy. I never had a problem disconnecting mine. either press down or pull up on the little tab and then just pull it out, i cant rember but it only takes a couple seconds.
Reactant
Mar 30, 2022 02:08 AM
MATT BOOTH
Technical and How-To Articles
Sep 22, 2015 08:35 PM
400H0
10
Aug 20, 2015 07:34 PM
tweeder
Jul 5, 2015 01:57 PM
