Gas tank pressure
Old Apr 10, 2007 | 04:40 PM
chiefsunset's Avatar
Default Gas tank pressure
I have a 2006 sportsman 800 EFI, the machine builds up an incredible amount of pressure in the gas tank, I assume the vent tube is blocked or kinked, has anybody else had this problem and do you know the fix for it. is the vent tuber easy to get too? After an hour or so of rididng I take the cap off and the pressure is so much it seems the tank should bust.
Old Apr 10, 2007 | 04:47 PM
trailbound's Avatar
If the tube on an 800 is the same as my 700, them its located right under the tank plastic next to the filler neck. My 02 has a little elbow screwed into the tank and then a small clear plastic hose connected to it, maby an 1/8" in diameter. I think it runs down into the steering neck. My budys grizz 660 plugs up in the mud and will kill his carburated machine.
Old Apr 10, 2007 | 08:45 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i would say that it must be pinched for sure. im surprised it still runs good w/ it that way.
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
2many2ride
Sep 27, 2015 04:35 AM
wrencher82
Sep 24, 2015 03:39 PM
MPDano
1) Engine problems..
Sep 20, 2015 09:48 PM
