Aftermarked Air Filter?
Old Apr 12, 2007 | 12:01 PM
thundercat's Avatar
Default Aftermarked Air Filter?
Has anyone installed a aftermarket air filter such as a K&N on their 400? IF so did you have any jet changes? Was it easy to install etc? ANy information would be helpful.--Thanks--Mike
Old Apr 12, 2007 | 01:50 PM
acpower's Avatar
my brother installed a K&N in his 400 auto. easy install, no jet changes, you can feel a little added power, nice filter.
Old Apr 13, 2007 | 09:39 AM
thundercat's Avatar
What year was is 400? Can you tell me what number K&N filter it was? Where did he install the fillter (air box?) thanks for your help.--Mike
Old Apr 13, 2007 | 05:50 PM
v2rider's Avatar
This is for all years 4x4 400 AC-4096-1
Old Apr 14, 2007 | 10:31 AM
thundercat's Avatar
What I'm wondering does the K&N give a small boost to the performance of the ATV? And where is it installed, in the air box or before it etc.--Thanks--Mike
Old Apr 14, 2007 | 01:12 PM
v2rider's Avatar
It replaces your stock air filter, and it gives a very small amount of gain in performance on an ATV. To alot of people, every little bit counts in performance. Alot of people also buy the K&N for its re-use ability over and over again.
Old Apr 14, 2007 | 03:21 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
More air flow also=less protection !!!!.....If more air is getting by that means less restriction!!!
Just my 2 cents................
I think K $ N are great for road uses...but not for off-road..............Caper......
Do you ride in the Dust alot????
Old Apr 14, 2007 | 07:17 PM
thundercat's Avatar
If you put a pre-filter on the K&N it should stop the dirt. You then have to keep it clean,--Mike
Old Apr 14, 2007 | 07:48 PM
Yes I agree,...Then your K & N is only as good as the pre-filter...Right!!!!!
Why have a high-end air filter if the pre-filter is restricting the air flow!!!!
That's why K&N don't make any since to me on a Quad!!!!!!!!
Thanks.............Caper.................
Old Apr 15, 2007 | 10:51 AM
thundercat's Avatar
Not to argue with you but the pre-filters are suppose to let 97% of air thru while helping to filter out the dirt. As I said you have to keep both clean to keep them working effectively. I do appreciate your comments, it helps me to make up my mind. Arctic sure has a elaborate filtering system.--Mike
