What other cylinders fit on a banshee?
With modifications, nearly any two-stroke twin of a relatively similar displacement will fit... I've seen Kawasaki 650cc jet ski jugs on Banshees, and I recently bought a Banshee tranny with Arctic Cat snowmobile cylinders and crank welded-on; the result is a high displacement "stock" motor.
But, if you're looking for a bolt-on increase in displacement which I think you are, you won't find cylinders from another engine that match up exactly to the banshee cases. Try the Superior Sleeve mono-block cylinders... 470cc with much less modifications.
