testing hot temp indicator light
Old Apr 17, 2007 | 03:31 AM
manomako's Avatar
Default testing hot temp indicator light
Whats a good way to test the hot temp indicator light?
i just installed a new one and i just had my engine rebuilt and the mechanic tested the thermal sensor and it works, but i just want to make sure the whole system works.
is it ok to disconnect the fan and run it until the light comes on? shouldn't do any damage should it? take into consideration it is a newly rebuilt engine and less than one tank on it.
thanks guys!
dave
Old Apr 17, 2007 | 06:52 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
you could but i wouldnt run it very long w/ out the fan or shuting it off. you take a chance of blowing head gaskets w/ overheating it and maybe warping the head.
Old Apr 17, 2007 | 03:40 PM
Instigater's Avatar
I have no idea what you have, but on mine, if I disconnect the plug on the left side near the thermostat housing, my fan kicks on and it flashes hot. Apperantly that is a normally closed switch, when I open it, those things are turned on!
Old Apr 17, 2007 | 03:42 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
he has a scramble i do beleave
Old Apr 25, 2007 | 12:05 AM
manomako's Avatar
yea, the disconnect trick didnt work, so when i was replacing the coolant hoses i added a temp sensor and gauge and warmed it up and watched the temp carefully until it warmed up enough. at about 225 degrees the light finally went on, so i know it works now, but the temp gauge will be my best friend from now on.!
thanks guys!
Old Apr 25, 2007 | 07:17 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
thats why i put a temp gauge in mine so i couls keep an eye on it when i'm mudding. works pretty good. your fan should kick on no more 210 i would beleave.
Old Apr 25, 2007 | 07:25 AM
manomako's Avatar
Yup,
the fan kicked in at exactly 190, so i'm a happy dude.
went to trenton yesterday and ran the pole lines and boy was it just mud and ponds of water! only got stuck once tho, my son got hung up...ahhhh the inexperience of youth!
dave
DeFox500
Jul 26, 2015 06:32 PM
Schneider
Jul 24, 2015 05:05 PM
ltrmc02
Jul 22, 2015 04:50 AM
micheleLeigh
Technical and How-To Articles
Jul 19, 2015 07:32 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
