2005 Viper 90R troubles
Old Apr 17, 2007 | 07:09 PM
chrisarrington's Avatar
Default 2005 Viper 90R troubles
I have been lurking here for about a year now and you guys seem to know your stuff. So here goes a good one. try to point me in the right direction. My son started to pull out on his Viper 90R yesterday and it died. It would not start back so today I got a new plug but didn't help. So I pulled the plug back out and no spark. When you turn the key on the dashboard does light up and tell you if it is in F, N, or R. Put it in Neutral and make sure the kill switch is on and it still will not spark. Does anyone have any specs on checking the coil, rectifier, regulator, or anythin else they think it might be. I blew the stator out as dust has been a problem before. Thanks guys.
Old Apr 17, 2007 | 07:38 PM
superbombman's Avatar
Chris from my experiance try the ign. switch if not that then try the cdi box.
I had a 06 viper 90r 4 stroke sold to a customer the other day so i got it running and cleaned it up the guy came to pick it up and the thing wouldnt start check for fire no fire so i exchanged the ign. switch still no fire replaced the cdi box out and i have fire now talk about wierd .....
Old Apr 17, 2007 | 07:43 PM
So the ignition could be bad and the dashboard still light up? I will unplug the CDI and try that and pull the switch out. I will just try and hot wire the switch to see if that is it.
Old Apr 17, 2007 | 07:53 PM
Okay I bypassed teh switch so it isn't that. Are there anyways to check the CDI other than plugging another one up?
Old Apr 18, 2007 | 10:54 PM
Sorry Chris there isnt anyway to check the cdi than to replace it
Old Apr 19, 2007 | 04:55 PM
What are the parameter's on checking the stator where I can at least rule that out before replacing the CDI. Also being that mine has reverse, do I have to stick with the same CDI or will any of them do?
Old Apr 24, 2007 | 05:45 AM
kstill's Avatar
Is the "N" on the dash flashing or is it on solid
Old Apr 24, 2007 | 08:14 AM
It is flashing. I pais no attention to that before.
Old Apr 24, 2007 | 08:37 PM
Does anybody here have a factory service manual on the 90R on CD? One that maybe I could get a copy of?
95wolv
Sep 27, 2024 12:00 PM
flyin-lowe
Dec 1, 2017 03:18 AM
mrtidy
Feb 3, 2016 05:00 PM
salixair
Nov 3, 2015 08:25 AM
Clint Russell
Sep 25, 2015 03:20 PM
