Lt80 Chain Adjustment
Old Apr 21, 2007 | 08:06 PM
bigdumbfun's Avatar
Default Lt80 Chain Adjustment
I just got a '99 LT80 for the boy and it runs nice. However the chain is REALLY loose and I couldnt find and adjustment on it. The sprockets and chain look to be in good shape. We have an LT50 also and through advise given on this page found all of the restictors and tricks to make it go alot faster than stock. So what is the hot set up for the 80? Not race mods just cheap and dirty stuff. I already looked for the exhaust restictor and it has been removed.
Thanks
Old Apr 22, 2007 | 10:41 AM
LT80's Avatar
LT80 Expert
No chain adjustment.
I make a nice adjuster.
Beginner mods:: remove 2 of the 6 rollers in the front clutch and shave the head .030. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Apr 22, 2007 | 02:27 PM
bigdumbfun's Avatar
No adjustment?!?! Then this chain must really be stretched. I could probably take a link out. Replace sprockets and chain? You make a nice adjuster LT80. That is something you sell I assume? Is it better than replacing chain and sprockets?
Thanks for the reply.
Old Apr 23, 2007 | 11:52 AM
freightrain's Avatar
If you don't want to spring for the adjuster, a larger front sprocket would tighten the chain a little and add some top end speed as well. Lots of people use an 11 tooth sprocket from a yamaha blaster. YMMV
Old Apr 23, 2007 | 01:37 PM
Hymis's Avatar
I took a chain roller that would be used for a motorcycle and drilled a hole in the plate and used that for some extra tension. I can send you some pics if you want. its super easy. You may be able to see it from this post " some other lt80 pics "
Old Apr 23, 2007 | 05:23 PM
bigdumbfun's Avatar
Thanks for the tips fellas. I like the sprocket idea because I am having a tough time finding 19" tires other than the stock ones and there seem to be alot of the 18". That sprocket would help offset the difference in size. The roller might still be necessary though too. There is alot of slop.
Old Nov 13, 2020 | 08:03 PM
Brandon Montgomery's Avatar
Where are you located and how can I get one of the chain adjusters from you
Old Nov 14, 2020 | 07:07 AM
LT80's Avatar
LT80 Expert
I haven't made one in years. I ran out of springs which are not available anymore.
If you need a adjuster, call midwest mini. Their adjuster is ok. Not much else. lol
Firefighter400
Oct 8, 2022 06:38 PM
frostphase
Aug 23, 2015 07:36 PM
goosemasterkl
Aug 23, 2015 11:36 AM
Bergmann
Aug 13, 2015 03:51 PM
willday08111217@gmail.com
Technical and How-To Articles
Aug 1, 2015 04:05 AM
