Jetmoto engine temp
Old Apr 22, 2007 | 08:58 AM
setters's Avatar
Default Jetmoto engine temp
Was wondering how hot the engine should run on the jm 125.After installing a K&N filter and a new chain on my sons jm 125 i went to put the chain cover back on and noticed the engine was smoking hot?You could feel the heat.Could this come from the chain being to tight.Could this little filter do this.I do no if you upgrade the exhaust you change jets but on just a filter?
Old Apr 22, 2007 | 10:37 AM
billl2099's Avatar
anytime you make a change in airflow, you're going to hafta to rejet, doesn't matter if its an airfilter or exhaust
Old Apr 22, 2007 | 01:16 PM
setters's Avatar
Also just put a K&N on my honda 250ex.The intructions say NO rejeting required?
Old Apr 22, 2007 | 04:19 PM
billl2099's Avatar
replacement k&n's that fit in the stock airbox normally don't require rejetting, but if you removed the stock airbox on your honda and replaced the stock airbox and airfilter with a clamp on k&n then rejetting will be required
Old Apr 23, 2007 | 09:16 PM
setters's Avatar
Did a plug check and it shows white,now what?
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Cummins Driver
Sep 11, 2019 01:22 PM
DeFox500
Jul 26, 2015 06:32 PM
ltrmc02
Jul 22, 2015 04:50 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
