4X4 Not working correctly.
Old Apr 24, 2007 | 07:11 PM
Motohoppie's Avatar
Default 4X4 Not working correctly.
Hi Gang,
My 2001 Polaris Sportsman 500HO is having an issue.
The left front wheel does not engage into 4x4. The right front wheel works just fine. The left hub will engage some if I got the RPM's really high.
The connections that run from the magnetic coil to up under the "hood" to the connections there (hope that explaines where I am). There is 2 of them there, 1 for the left hub and 1 for the right hub. If I switch them around the right hub will work eaither way, but the left will not. This tell me that the problem is lower down the wire towards the magnetic coil or even farther.
The clutch is working fine when tested by hand. There is an adjust that can be done of outer to the inner pole, by moving the outer pole. If i find that when I measure this gap and it needs adjustement, could this be what the problem is? Or more clearly of a question.... Can this "gap' being incorrect cause the problem I'm having?
I'm going to check the wiring to make sure there is not a bad spot between the connecion and the magnetic coil also.
The fluids are fine and correct.
Stuck in in 3.2 X 4 in Kansas,
John
Old Jun 26, 2007 | 07:25 PM
Motohoppie's Avatar
I fixed the 4x4 drive. I just tapped the sleeve seal inward with a rubber mallet and got the gap between the inner and outter poles into specs. It works perfect now.
hugemoth
Jul 20, 2020 03:28 AM
rcappie4
Jul 18, 2015 07:51 AM
timster911
Jul 13, 2015 01:57 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bikedad3
Jul 2, 2015 02:15 AM
