2004 400 Auto Clutch and Belt Question
Old Apr 25, 2007 | 11:55 PM
nathan1314's Avatar
Default 2004 400 Auto Clutch and Belt Question
I removed the belt cover on my 2004 400, Everything looks in decent shape but does anyone know how wide a brand new belt is for a 400?
Also is there suppose to be grease in the clutch rollers?
Thanks
Nathan
Old Apr 26, 2007 | 12:07 AM
buckaroo50's Avatar
Originally posted by: nathan1314
I removed the belt cover on my, Everything looks in decent shape but does anyone know how wide a brand new belt is for a 400?
Thanks
Nathan
I do, I do, but I am not telling...
Old Apr 26, 2007 | 12:08 AM
buckaroo50's Avatar
Thanks
Nathan
The belt is 28.55 mm wide = 1.12 inches....
Old Apr 26, 2007 | 12:10 AM
buckaroo50's Avatar
Thanks
Nathan
Can't help you on the grease, because I don't know what clutch rollers are...
Old Apr 26, 2007 | 12:22 AM
nathan1314's Avatar
drive face rollers located in the driven pulley, does that make better sense?
Old Apr 26, 2007 | 01:14 AM
buckaroo50's Avatar
NOPE!!!
But I just checked the service manual, for belt inspection and changing and did not see any mention of grease. I will check the servicing of the clutch and if I find anything I will let you know...
Yes there is grease,
Apply multi-purpose grease to the O-rings and
grease seals on the movable face; then install on
the fixed face making sure the alignment marks
are properly aligned.
Inspect two grease seals in the movable face for
nicks, cuts, or damage.
Install the three pins and spacers into the fixed
face hub; then pack the cam slots in the movable
face with multi-purpose grease.
Old Apr 26, 2007 | 06:50 PM
nathan1314's Avatar
Thanks for the quick replys, most helpful.
Nathan
Old Apr 26, 2007 | 08:39 PM
buckaroo50's Avatar
Nathan
I don't have a clue what I am doing but I am glad that it helped... I'm just a dummy...
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
toonces
Jul 31, 2015 09:27 AM
Mikesohio
Jul 26, 2015 10:51 AM
200es
Jul 10, 2015 09:09 AM
