200x will only start buy pulling
Old Apr 26, 2007 | 11:07 PM
lawnboymelvin's Avatar
Default 200x will only start buy pulling
hello. my friend has a honda 200x. im going to help fix it for him. it will only start if you pull it with the other 3 wheeler. it has only started maybe 2 times buy the kick start. he said he has set the timing but i think that might be the problem. it smokes alot but runs good when you start it. it fires right up when you pull it but with the kick start it has nothing. its like theres a spark probelm or the timing is off.
what do you think the problem might be.
need to know by this saturday
thanks
melvin
Old Apr 27, 2007 | 05:50 PM
Splat's Avatar
going out ona limb here - but have you pulled the lead to the plug to see how strong a spark your getting?? might need to rewind the stator - just a guess here but i would start there to see how strong it is.
Old Apr 27, 2007 | 06:31 PM
ok thanks no i dont think he has checked that were going to be working on it on saturday so i will let you know
thanks
melvin
Old Apr 28, 2007 | 10:58 PM
hello. good news. the 200x had good spark and the timing was all good so we push started it and sprayed carb cleaner in the carb and after that its always started on the kickstart
thanks
melvin
MikeyBoyesq
Nov 27, 2020 02:44 PM
200x hill climber
Ask the Editor
Jun 10, 2015 11:11 PM
1000gade
May 27, 2015 12:37 PM
bigmanm
Jun 28, 2000 10:34 PM
PLEA$URE
8
Jan 31, 2000 10:55 PM
