Scrambler 500 spark plug mod
Old Apr 28, 2007 | 02:11 AM
pontiac2m8's Avatar
Default Scrambler 500 spark plug mod
I have attempted tonight to change the plug on my 04 scrammy and now that I am reading the forum my fears are right I have to take the plastic and tank off. Why include a spark plug wrench when it would be quite a job on a trail. Anyways I was thinking can a access whole be cut in the side of the plastic to give me easy access? What side should it be on? Just thinking that cutting a opening and then riveting a flat piece of rubber over the whole would keep it lokoking half way decent and give me access under the gas tank without major surgery!
Any thoughts?
Old Apr 28, 2007 | 12:52 PM
pontiac2m8's Avatar
Any thought if this will work?
Old Apr 29, 2007 | 11:41 PM
Russ136's Avatar
You can get the plug out without taking off the plastic and the tank. If you need some help let me know.
Old Apr 30, 2007 | 05:05 PM
hikuntryslim's Avatar
i have changed mine without removing anything [ its a pain in the butt though ] i took the hose nozzle in blasted out the area in case there was any dirt or debris down around the plug area ....
Old May 1, 2007 | 06:45 PM
outlaw77's Avatar
it is a pain in the butt,, but if you are a contorsionist or have little tiny boy arms you can get it easily.. otherwise it is a pain..i found that bending that wonderful tool they give us helps a lot, but it can be done with a lot of patience good luck
Big bousse
Sep 26, 2015 10:42 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Dirtbikemike1
Jul 21, 2015 04:13 AM
ghost civic
Jul 19, 2015 10:13 AM
Bob Maurice
1) Engine problems..
Jul 14, 2015 09:05 AM
