fan overide on 500 efi
Old Apr 28, 2007 | 08:06 PM
gates59's Avatar
Default fan overide on 500 efi
Has anyone tried to overide the fan on a sportsman 500 efi. I did it and the hot light come on rite away. Shut off and it goes away. I was thinking about some sort of diode to stop the current from going back to the pdm. I'm guessing that is my problem. Any advice THNX.
Old Apr 28, 2007 | 08:19 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
What year is the qaud?.....he 2005/2006 HOT light is controlled by the ECM or PDM...Electronic control module,Power distridution module.........Just to let you know.........Caper......
Old Apr 28, 2007 | 08:25 PM
The HOT light is controlled by pin # "D" Blue/White Engine signal hot
This provides a ground path for the lamp.......Removing this will keep the lamp from comming on!!!...........Why would anybody want to remove this.......I don't know!!!!!NOT me
It saved the engine on my wife's the second ride out.........Back of rad plugged solid!!!!...Caper...
Old Apr 28, 2007 | 08:27 PM
The orange and black is power to the fan.......Why not just send power to this for your override....................Then your hot light can still be connected???...Caper.........
Old Apr 28, 2007 | 08:31 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
im trying to figure out what he wants to do. is the lgiht stuck,or is the fan not working? i know on mine if you want the fan to run, just pull the wires off the sensor and it automaticly comes on(fan).
Old Apr 29, 2007 | 07:03 AM
gates59's Avatar
When you pull the wires off the sensor the hot light comes on right away. I don't want that. I have the 06 and the fan and sensor are working just fine. I want to control the fan by turning it on when I want. I want to be able to leave it on for a while and turn it off just before I get thought a mud hole. Don't want it on in a hole. All I'm doing is putting power direct to the fan + wire. Is there a better way.
Old Apr 29, 2007 | 08:00 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
check here
Old Apr 29, 2007 | 09:43 AM
Well read that.........The fan "ON " light would sure be nice.........I sure would like to know how often my fan comes on and when.........That's one "MOD" I just might do!!!!!!.Listen to me........Am starting to be like the rest!!!!!.....LOL...LOL....LOL......Caper........
Old Apr 29, 2007 | 12:30 PM
gates59's Avatar
That switch does look nice but it will not work with the 500 efi model. No matter what I do the hot light will come on when power is applied to the + of the fan. I guess I'm just stuck getting an light to tell me when it on and that's it.
Old Apr 29, 2007 | 02:48 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
it might be the emc controls the pod w/ the fan sensor and when the fan is on when not turned on by the sensor tels the emc to turn the light on. if that makes any sence.
Adrian Turner
Aug 30, 2015 04:08 PM
tutus
Nov 6, 2005 08:43 AM
zappa24
Sep 22, 2005 06:12 PM
Lo
Jun 28, 2004 12:46 AM
Camo-man
Feb 6, 2004 07:44 AM
