Found Problem, How Do I Fix?
Old Apr 29, 2007 | 09:14 PM
TheBomb650's Avatar
Default Found Problem, How Do I Fix?
My DS started acting up. If I have the headlights off you only can get going so fast and then it cuts out. But if I have my headlights on it runs normal. Any one have an idea? Thanks....
Old Apr 29, 2007 | 09:53 PM
ScoobyDFW's Avatar
voltage regulation is not working, probably bad rectifier.
Old Apr 29, 2007 | 09:59 PM
DSRIDER650X's Avatar
get a new rectifier/regulator...do a search on here for either one. Regulator or rectifier (they are the same thing, but diff. people use diff. names for them). You will see about 1000000000 more post where others had the same problem...including me! Good luck..check the garage post to get a new one. Remember that the plug is diff. for diff. year models! They changed after 03, I think, it was somewhere around in there. But you can always hardwire it! I know that nickds650 has one....
GOODLUCK!
Old May 6, 2007 | 11:42 PM
chirochris's Avatar
get a new reg....
search my name
and ground that pig fast...it has a short...
mine did the exact same thing..head lights and all
i got a new reg, battery and it still went wrong until i grounded it to the sub and main frame...no issue so far
Sjrpp
Nov 15, 2019 09:59 PM
toonces
Oct 16, 2019 12:11 PM
Sjrpp
Jun 2, 2019 07:25 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
