Rear suspension sag
Old Apr 30, 2007 | 12:46 PM
MNScrambler's Avatar
Default Rear suspension sag
Does anyone know what the proper sag/sit-in of the rear suspension on a Scrambler is? I want to see if I have my rear spring set-up wrong because I'm getting a lot of kick-back in the rear. If I'm going down a trail and hit a bump, it feels like the front end works fine, but the rear end will bounce up off the ground. Do I just need to have someone play with the rebound valving to help this?
Old Apr 30, 2007 | 05:15 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i would check the shocks to see if there gone bad and wont rebound any more. just a thought. i would guess you wouldnt want much more then 1 to 2" drop when you sit on it. just a guess though.
Old Apr 30, 2007 | 11:17 PM
Instigater's Avatar
5 years old, maybe it needs recharged!
Old May 1, 2007 | 10:05 AM
ryker77's Avatar
What is the spring setting on? And how much do you weigh?
Old May 2, 2007 | 03:59 PM
The spring is set at about a 1/4 inch from all the way soft and I weigh about 180 lbs.
I've looked through the manual, but I don't see any "sit-in" or "sag" recomendations. Does anyone know what they suggest?
Old May 4, 2007 | 10:16 AM
Polaridoo's Avatar
I have noticed the same issue with my 2001 Scramber also. If this thread doesn't get an answer, I guess I will start decreasing the sag until it feels right. I have not actually measured the sag yet, but it looks to be at least 4 inches (static sag). I think most all the Scramblers come with way too soft of a rear spring.
mywifesquad
8
Sep 21, 2015 08:20 AM
Tim Shoe
Sep 7, 2015 12:15 PM
black_thunder
Sep 7, 2015 01:24 AM
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
snowolson
Aug 31, 2015 03:51 PM
