sportsman fuel pump
Old Apr 30, 2007 | 01:05 PM
edmo500's Avatar
Default sportsman fuel pump
my 96 sportsman 500 has some power issues....it will idle fine all day long, start perfect, but has no get up and go. I have heard it could be the fuel pump diaphrams are getting stretched and not giving enough pressure. Has anyone else heard of this? wanted to get some feedback before I tore into it. Any other ideas what I might be? thanks
Old Apr 30, 2007 | 01:58 PM
SPORTSMAN70003's Avatar
Have you checked and cleaned your carb? You also might what to check your fuel filter and air filter.
Old Apr 30, 2007 | 02:01 PM
edmo500's Avatar
I have been through and cleaned the carb 3 times, fuel filter seemed to pass air through easily when I blew through it. Cleaned air filter, but I am getting a real "throaty" sound in my air box (like is sounds if you run it without the air filter)
Old Apr 30, 2007 | 02:03 PM
How many miles on your 500? You could possible have a wore out cam.
Old Apr 30, 2007 | 02:11 PM
edmo500's Avatar
it does have 4000 miles on it, but I am on my second cam right now. I thought It could be a valve not opening, but im hoping its just a fuel issue.
Old Apr 30, 2007 | 03:44 PM
Overdrive's Avatar
You already wore out one cam? Let me guess Polaris oil?
Old Apr 30, 2007 | 05:01 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i heard the older ones had soft cams. i would doubt it was the fuel pump. just my opinion.
Old Apr 30, 2007 | 07:10 PM
Overdrive's Avatar
If I remember correctly it was 96 or 97 when they had a batch of bad cams.
Old May 1, 2007 | 10:27 AM
edmo500's Avatar
I have talked with a few mechanincs. they say it sounds like a fuel issue, either a vent on the back of my fuel pump (which is a pain in the a$$ to get to), or my float is possibly bent causing the needle to only partially open. So, I will be tackling that this weekend. If anyone else has any ideas let me know!! thanks!!
Old May 1, 2007 | 09:44 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
it alomost would sound if it was a lack of gas issue it would run extremly lean and tend to back fire a litle when you try to push it. just a thought. and also if you open the choke while its loosing power and seems to be better a little then it would be a lack of gas.
Ask the Editor
12
Jul 21, 2015 06:57 AM
trouttracker
Jul 19, 2015 11:50 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
Mikea1978
Jul 4, 2015 12:37 PM
