atv wont run
Old May 4, 2007 | 07:46 PM
blueman1388's Avatar
Default atv wont run
i have a 110cc chinese atv. It turns over fine but wont seems to run. it just turns over endlessly. Once and awhile it will start for 1-5 secs then die back out. any suggestions?
Old May 5, 2007 | 09:38 AM
LT80's Avatar
LT80 Expert
Did you clean the carb yet?
That's first in my book.[img]i/expressions/face-icon-small-smile.gif[/img]
Plug got a good blue spark?
Compression?
Old May 5, 2007 | 10:29 AM
illin's Avatar
Probably not getting any fuel.
Put a teaspoon of fuel int he spark plug hole and try to start it. If it fires right up...you have just narrowed your issue down to the carb.
Make sure your petcock is actually on...sometimes the Chinese get on/off confused. Also, make sure your gas cap is venting and you dont have a vacuum on your gas tank...hat happens too.
Old May 6, 2007 | 04:05 PM
Guest
Guest
Posts: n/a
if you haven't changed the plug do that now put a ngk plug in check gas make sure your getting gas.
it might be the woodduft key flywheel key.
Old May 6, 2007 | 11:55 PM
chabat's Avatar
This happens to me on my 150cc buggy - chinese engine... It is always a fuel problem.
Old May 7, 2007 | 12:27 PM
abramsgunner's Avatar
I second the spark plug idea. I have the Sunl mini 110.. was running good, then would not start, just gurgle for a second or two. Replaced the cheap chiniese knock-off spark plug with an NGK, and it runs better than new.. starts first try every time. Also, make sure you have at least half a tank of gas, as the carb doesn't get fed right if the fuel is low depending on how your fuel line is run.
