Sport Quads Discussions on sport quads.
Predator 500 Transmission Problem!!! help
Old May 7, 2007 | 08:03 AM
macster403's Avatar
Default Predator 500 Transmission Problem!!! help
I have an 04' Predator which I recently started racing this year. The quad is well broken in and never had any problems shifting last year. I took the quad to an indoor track and came down hard on a jump and the chain popped off and was lodged in the front sprocket. After fixing, I noticed I only have 2nd and 3rd gear. We removed the engine and split the crank case, and found no bent shift forks or drum problems. I even took the trany half to a polaris mechanic who saw nothing wrong. He told me to check for a clutch issue. I put a friends newer clutch in after putting the motor back together. Now i only have 3rd and 4th?? If i try to downshift it goes into neutral and then upshifting it slams into 3rd. I run only PS4 Oil in it, and the motor runs great after new rings and head work. Not sure if anyone has had this issue before. Not sure if theres anything under clutch cover i can check for before pulling motor out again. Any help is appreciated!
Mac[img]i/expressions/face-icon-small-mad.gif[/img]
Old May 17, 2007 | 08:47 AM
spyder6's Avatar
sorry about your issue, and i wish i could help more, but you have a awefully strange problem. i dont know if you still have your case appart, but i would look at everything that connects to the front sprocket and work your way backwards. sorry im not of more help
1966F100
Jul 14, 2015 12:19 PM
shewshew989
Jul 14, 2015 03:09 AM
1966F100
Jul 12, 2015 03:08 AM
steveo612
Jul 11, 2015 08:35 AM
bikedad3
Jul 2, 2015 02:15 AM
