Front diff drain bolt snapped wile tighting(update on what worked)
Old May 7, 2007 | 08:45 PM
toddmh's Avatar
Default Front diff drain bolt snapped wile tighting
Gahh what should I do??The bolt snapped close to the head,this sounds like a large problem,it is not leaking with the new oil in it..Should I just leave it till I change the oil again lol ..Any ideas what to do to get this thing out??
Old May 7, 2007 | 08:56 PM
cluby's Avatar
well if it's the drain bolt then most diffently get it out it could fall out and toast your diff
Old May 7, 2007 | 08:59 PM
nedflanders's Avatar
i broke our rear diff drain bolt on a 250EX. so far, it's still in there. I don't think it'll loosen off on you because it probably broke from over-tightening. You might wanna try drill and an EZ out. BUT, if the ez-out snaps, then you're really hooped.
heard some guys say try to weld a head on it. the heat from welding should loosen it, plus the head will give ya something to turn.
Old May 7, 2007 | 09:08 PM
toddmh's Avatar
yeah I'm worried about drilling it to use a easy-out,If the bit catches it and sends the stub into the diff ..Eeeek don't want to think about that [img]i/expressions/face-icon-small-sad.gif[/img]
Wish I had a welder,I'd weld a spike onto it and turn it out,I don't think it is in there very tight
Old May 7, 2007 | 09:56 PM
squeege's Avatar
You can get left hand drill bits......
Old May 7, 2007 | 09:57 PM
is there ANYTHING sticking out? could you pound a multi-point socket over it, and turn it out that way (it's worked for me many times on rounded bolts).
OR, could you grind or cut a slot with a hacksaw, to make a slot screwdriver work? I've had success with that too.
Old May 8, 2007 | 07:38 AM
toddmh's Avatar
Now that is new to me..I will look into that today thanks [img]i/expressions/face-icon-small-smile.gif[/img]
and no the stub is just inside the case,I have done that with with rounded bolts also..but won't work here [img]i/expressions/face-icon-small-sad.gif[/img]
Thanks for the ideas guys...
Old May 8, 2007 | 08:02 AM
07Wolvey450's Avatar
if its not to tight i would buy some liquid weld stuff, ferget what its called exactly, and "weld" anything you can find thats flat on the bottom and take a pair of pliers and spin the bolt out, its probably not on there too tight. just my 2 cents, i cant think of anything better than that other than the lefty drill bit
Old May 8, 2007 | 01:55 PM
JB Weld. but lots of others making a similar product.
Old May 8, 2007 | 02:07 PM
ctateusa1's Avatar
Left handed drill bit and an ezout would be the best way.
