Rancher won't start - Any Help?
Old May 7, 2007 | 11:24 PM
Hutchie's Avatar
Default Rancher won't start - Any Help?
Hello to everyone, this is my first post! I have a 2004 Rancher ES with 725 miles. It has run perfectly until this evening when nothing happens when we try to start it, other than we hear a click which appears to be coming from the little box right behind the Battery. The Battery checks out fine and I put it on a charger just to make sure. Any advice as to what might be the problem?
thanks
Old May 8, 2007 | 03:34 AM
Gimpster's Avatar
Eather the starter brushes are stuck or worn beyond spec. If the solenoid clicks, it is working. A test light on the starter's cable terminal itself and the other end of the light to chassis ground, will most likely show voltage to the starter while the starter button is depressed ( Ignition switch on). This will confirm the starter brushes are bad.
Old May 8, 2007 | 07:51 AM
Hutchie's Avatar
Thanks Gimbster, that makes sense!
Old May 8, 2007 | 10:12 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
It has a pull backup starter, or you can just push start it. Have you tried that???? That will eliminate other possible causes besides the starter itself........
neilbedwell
Nov 10, 2018 11:02 AM
Marc Parish
Jun 26, 2015 09:37 AM
ROWALKER
Jun 15, 2015 05:38 PM
RedRancher
Jun 4, 2015 12:29 PM
1000gade
May 27, 2015 12:37 PM
