disabling neutral start?
Old May 8, 2007 | 12:44 AM
Sontizzle's Avatar
Default disabling neutral start?
is there a way to disable the starting it in neutral function? its weird because sometimes i can start it in gear while holding the clutch and other times it wont start unless its in neutral.
Old May 11, 2007 | 03:31 PM
TIC's Avatar
TIC
those "sometimes it will start" are you also holding the front brake handle?
My rubicon will start without having it in N if I hold the brake handle.
Old May 12, 2007 | 12:02 AM
Sontizzle's Avatar
i never thought about that, ill try it once i get it back from the shop.
Old May 12, 2007 | 11:05 AM
TractorPacker's Avatar
Do you have a balloon?
There is a switch in the clutch perch. It has 2 wires going to it. If you cut those 2 wires and connect them together, the safety switch will be by passed.
Old May 13, 2007 | 10:21 AM
TwinCam95's Avatar
instead of cutting them and ruining it in case you ever want to change it back to stock, just connect them to an automotive type fuse. You may need to file the blades on the fuse to narrow them a bit, but you are essentially doing the same as connecting them together, but without cutting the factory connectors off.
Mkp
Mar 28, 2020 03:50 AM
Dabears1983
Jun 16, 2015 12:17 PM
Steven Bandemer
Jun 9, 2015 08:50 PM
jayking232003
Jun 9, 2015 02:54 PM
1000gade
May 27, 2015 12:37 PM
