06 500 AUTO MOTOR NOISE
Old May 11, 2007 | 01:01 AM
KY06AC500AUTO's Avatar
Default 06 500 AUTO MOTOR NOISE
I have a 06 500 and during accelaration there is a pinging or rattling noise. I have had yamaha's with the similar sound,but this is my first experence with a suzuki motor. Is this normal for a suzukl and is anyone else hearing a similar sound?
Thanks
Old May 11, 2007 | 01:06 AM
HR's Avatar
HR
hum. Well i have teh same ATV and i can't say i have any pinging.. but my ears are shot from shooting so much. but i'dd say mine sounds like a normal small engine. maybe try some higher octane gas. and check your oil level.
HR.
Old May 11, 2007 | 01:08 PM
buckaroo50's Avatar
Thanks
I could be a number of things, I had a similar sound and it turned out to be a clip on some of my plastic was vibrating against my exhaust shield and transmitting the sound to the engine - I could have sworn that it was engine noise.
Ping from gas is a lean mixture, low octain, or timing is off - no adjustment for timing but an incorrectly gapped spark plug will change the timing. Try regapping the spark plug and maybe make the carb a little richer. I like my sparkplugs to be a dark chollocate brown or close to black (but not sooty). This way it eliminates some possibility of running too lean and burning a hole in the piston.
Check the plastic on the exhaust pipe side and make sure it doesn't vibrate against the exhaust.
It could possibly be a loose/streched timing chain - would make noise and also throw your timing off.
Try a higher octain gas.
Put some carb/injector cleaner in your gas to clean out your fuel system.
You may also want to check the gap on your valves. Incorrectly gap can cause preignition/ping. - valves closing late.
Could also be a worn camshaft...
Could also be the CDI ignition, or battery, magneto related problem.
Other than that I don't know - lol
Start with the free and least expensive things and go from there.
bmxatv10
Oct 14, 2022 06:23 PM
fd24
Jan 16, 2019 08:59 AM
caveeagle
Sep 19, 2015 01:20 PM
JDawg8309
1) Engine problems..
Sep 12, 2015 02:24 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
