brain fart!
Old May 12, 2007 | 08:21 PM
snowpacker's Avatar
Default brain fart!
I have a 2004 700 efi and I ripped rear left upper (closer to gear box) cv boot. Right now I got the shaft out with the cv joint exposed (***** are seperated) now my question is (Brain fart here cause I've done this before but don't remember how) how to get new boot on seeing that half of the cv joint is still attached to the shaft.?
Next question is the round hub that goes into the gear box and held in with that little $1.20 c-clip...how much play should that have once its in the gear box? I have about 1/4" free play on both sides. thanks in advance.....
Old May 12, 2007 | 10:57 PM
SPRINGHEAD's Avatar
Default brain fart!
did you buy your parts yet,if not gorilla axle does the job for you usually cheaper than you can buy the parts yourself
Old May 12, 2007 | 11:06 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default brain fart!
if hes only replacing the boot it wouldnt be lol. not sure what you mean about side to side play. are you refering to in and out play that there is a little.
Old May 12, 2007 | 11:32 PM
snowpacker's Avatar
Default brain fart!
ya I guess you could call it in and out play.......I have a new boot on the way, just like to know how to put it on shaft with the inner half of the cv joint still on shaft
Old May 13, 2007 | 07:07 AM
manomako's Avatar
Default brain fart!
You've got to separate the axle from the cv joint. either by removing the c-clip while the axle is still attached (which is tricky), or by "gently pounding it off".
stick it in a vice and either yank on the cv joint using that 'play' you mentioned or whack the cv joint with something soft like a piece of 2x4 or brass hammer.
grease joint, put clamps on axle, then boot and pound cv joint back on axle and clamp boot.
ta da!
good luck
firsttimerider
Sep 26, 2015 01:49 PM
SouthCarolinaRedneck
Aug 19, 2002 12:19 PM
rodman922
Aug 4, 2002 11:12 PM
BigTheron
Apr 2, 2002 08:31 PM
bartolo
Dec 23, 2000 02:14 PM
