blaster oil
Old May 13, 2007 | 01:06 AM
Slash182169's Avatar
Default blaster oil
hey i am going to get the oil injection block off kit for my blaster and i was wondering what the ratio is for it i have an 02. not that that matters
Old May 13, 2007 | 01:51 AM
tallbigboy82's Avatar
Default blaster oil
I have a huge Favor to ask of you. I have a 03 blaster and I'm trying to remove the rear axle, and I cant get the sprocket off, and wanted to know if you have any ideas???? I've heated with a torch, I've pounded it with a sledge hammer. so any help you could give would be great Thanks Slim Slimboy23@hotmail.com
Old May 13, 2007 | 04:26 AM
JLsparky7's Avatar
Default blaster oil
I believe the oil injection runs it at 20:1 which is rediculously rich. I would go with 40:1 if you are running a good synthetic. If your running walmart stuff or yamalube I would go with 32:1
Old May 13, 2007 | 04:28 AM
JLsparky7's Avatar
Default blaster oil
It should slide right off. Try some WD40 or penetrating oil. The sprocket slides off, the axle is a pain to get out of the carrier though. Put the hub castle nut on the end with the sh1tty socket and beat the **** out of it.
Old May 13, 2007 | 10:49 AM
Default blaster oil
yea when i had to change my bearings it was a pain to get it all off the best thing to do is not stop tryin just pull and then wd40 pull more then more wd40 pull more wd40...just repeat that and eventually itll come off
Old May 13, 2007 | 10:53 AM
Default blaster oil
also to make it even easier take off the carrier so then the axle comes off the quad along with the carrier but dont take the other wheel off and then set the wheel down so the axle and carrier and sprocket are pointing up then stand on the wheel and pull up that gives the most force but just be careful that when ur doing this that if the sprocket pops off u dont go flying off the tire because of how hard u were pulling..
Ahtatu
Sep 28, 2015 12:14 PM
nastyblaster100
Sep 13, 2015 01:19 PM
1966F100
Aug 21, 2015 07:10 PM
scott1988
Aug 18, 2015 08:44 AM
315blaster
Aug 8, 2015 08:13 PM
