Need tech. assistance... Is this a V. Regulator problem?
Old May 14, 2007 | 04:40 PM
RobAlford's Avatar
Default Need tech. assistance... Is this a V. Regulator problem?
I have a 2000 500 Auto. If I turn my fan off it will die, sometimes with the fan on I can't do much more than idle unless I turn the lights on. It runs fine with the lights on and fan on... Isn't this going to be the voltage regulator? If so, where is the cheapest place to get one. Thanks in advance, Rob
Old May 17, 2007 | 12:30 AM
RobAlford's Avatar
No one has seen anything like this? Does anyone agree or disagree with my diagnosis?
Old May 17, 2007 | 01:33 AM
swampyjunior's Avatar
I seem to remember a post on here a while back in which his engine would not run past an idle if the lights were on or something like that. He replaced the voltage regulator and his problem was fixed.
You can do a search for voltage regulator and probably find it.
I have not had any trouble like you described or with a voltage regulator for that matter. But, based upon what I read and how you described your problem it does sound the same.
There is a way to test the voltage regulator in the maintenance manual. It involves using a volt meter and such.
Those things are pretty spendy so I would check all my connections first, which you probably have done already. Then test the regulator. Replacing it if needed.
SJ
skinnyr6
Aug 25, 2023 02:18 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Schneider
Jul 24, 2015 05:05 PM
hondarider1234
Jul 21, 2015 11:53 PM
200es
Jul 19, 2015 04:50 PM
