1986 trx 125 carb problems
Old May 17, 2007 | 08:57 PM
texretvet's Avatar
Default 1986 trx 125 carb problems
I have an'86 trx 125 fourtrax, that I have rebuilt from the ground up. Everything seems to be working great, and it runs good. The problem is this:
It starts and runs just fine, but it seems that once everything gets up to temp, it will just die. I set the carb to the right setting with the air/fuel screww and the idle screw.
The thing is, once it gets up to temp and dies, you can choke it and it will run as long as you leave it choked.
Everything in the carb is brand new and the carb has been cleaned like new.
Any suggestions?
Thanks.
Old May 17, 2007 | 10:16 PM
lrod's Avatar
You need to run a wire through the pilot jet.
Old May 19, 2007 | 01:15 AM
JRM's Avatar
JRM
yup, clogged pilot, or maybe a air leak causeing it to be to lean
Ty Speece
Jul 2, 2015 04:59 PM
TJM
Jun 11, 2015 01:28 PM
generalpops
Jun 5, 2015 08:23 PM
generalpops
Jun 3, 2015 08:25 PM
kevbowe
Jun 1, 2015 01:17 AM
