Works shocks for warrior
Old Dec 26, 2000 | 02:44 PM
Theputsman's Avatar
I have a set of works triple rate shocks set up for a Blaster, Can I use them on my warrior. I took off the stock shocks from the warrior and they are the exact same length and the brackets and bolts line up perfectly. I installed them on the warrior and other then feeling a little spongy they seen to work fine. Is this OK or do they need to be set for a warrior, I know the warrior is a lot heavier.
Old Dec 26, 2000 | 09:16 PM
speedy2's Avatar
is any thing wrong with yourrea shock????if nothing is wrong with it i will buy it if you are willing to get read of it!! thanks email me at aintskeered@nexet.net if you will sell it thanks
Old Dec 27, 2000 | 01:27 PM
Theputsman's Avatar
Which shocks are you interested in, The blaster or warrior. I only replaced the front warrior and blaster shocks.
Old Dec 28, 2000 | 12:45 AM
speedy2's Avatar
just the warroir rear shock cause i blew mine about a month ago and its hard landing a jump with a bad shock..
Old Dec 28, 2000 | 02:14 AM
Theputsman's Avatar
Sorry I did not replace the rear shock, Only the fronts.
Old Jan 1, 2001 | 04:13 PM
DesertRaptor's Avatar
xxxx
Reactant
Mar 30, 2022 02:08 AM
hugemoth
Jul 20, 2020 03:28 AM
Jkfx400P
Jul 6, 2015 10:04 AM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bikedad3
Jul 2, 2015 02:15 AM
