STEERING HELP NEEDED
Old May 20, 2007 | 01:36 AM
bigstuff98's Avatar
Default STEERING HELP NEEDED
SO MY SON TAKES THE 2006 WOLVY 450 OUT TODAY ON THE TRAILS. HE WAS GOING BETWEEN 3 AND 6 MPH AROUND A TURN & SMACKS A SMALL TREE.THE BARS A NOW BENT ABOUT 2 INCHES BACK TO THE RIGHT WHEN THE WHEELS ARE PERFECTLY STRAIGHT.BENT AS IN THE STEERING TUBE WAS LOOSE OR SOMETHING. LIKE WHEN U ARE ON A BICYCLE & THE FRONT WHEEL IS STRAIGHT & THE BARS ARE CROOKED . HOW DO I FIX THIS ? THANX 4 YOUR HELP
Old May 20, 2007 | 11:57 AM
SBuckJ's Avatar
Reconranger (automatics are for sissies)!
IF it's like my Kodiak, at the bottom of the steering stem you'll find a nut. Loosen that, straighten the handlebars, then retighten the nut.
Buck
Old May 20, 2007 | 08:55 PM
bigstuff98's Avatar
this being part # 13 correct ?
http://www.187rideeasy.com/fiche_section_detail.asp
thanx for the info.i believe it is a 22mm size that is required. have to use an open end.socket drive is too big
Old May 21, 2007 | 03:40 PM
SBuckJ's Avatar
Yes that is the part another site is http://216.37.204.206/xtremepo...sp?Type=13&A=343&B=30
Buck
3quadbob
Sep 18, 2016 09:46 PM
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
Mphillips
Jul 2, 2015 07:20 PM
toonces
Jun 30, 2015 11:19 AM
